Outdoor Security Mount (VMA1000) installed on ceiling makes camera view upside down
  • 2 Replies
  • 3804 Views
  • 3 Likes
JodiH
I just ordered two Arlo camera's for the outside / back of my house.
Was planning on installing the Arlo's to the Outdoor Security Mounts (VMA1000)
to the ceiling under the overhangs instead of into the siding. I know the mounts
have a 90 degree tilt, but this will make the camera's face the ground, and if left
in the vertical position, it will be upside down.
Does the Arlo software allow for a 180 degree flip for viewing and recording?
Is there a fix for this, any suggestions, maybe another mount brand?
Many thanks, Jodi
F150Fan
Go into your device settings. Select Video Settings and toggle on Rotate Image. This will give you 180 degree video rotation.
Yes, the SW can flip the image...simple toggle on/off
F150Fan
