I have 2 cameras that will not syn with router ... all I get is orange blinking light?? can anyone help PLEASE?
Arlo cameras sync to the Arlo base only
Q cameras sync to your router/wifi
If you mean the Arlos cam, do a QUICK push on the base sync button ( don't hold ) and then press the camera button a few secs later.
If you mean the Q cam, then make sure the SSID and passwors are exact ( previos sw had problem with non regular charactors in password )
slup,
Were you able to successfully sync your cameras after a quick press and release as described above?
Please let us know,
