Opening Ports
I have bought on Amazon the following product:
ARLO by NETGEAR Smart Caméra VMS3330-100EUS
But I am unable to use it as I have to open a port on my routeur and I have no clue at all which value I have to enter in order to open the port.
Can somebody tell me which value I have to fill in as a rule ?. You can find below the screenshot of my routeur.
Many thanks in advance
Marie-Lina
Unless you've specifically blocked a port, it's likely not necessary. WHich firewall are you referring to, router or software/computer? The router probably isn't blocking it but the computer firewall/antivirus could be by default.
If you really need to open ports, both 80 and 443 need to be open. 80 should already be open since you can web browse but 443 could be an issue.
