One camera will not set up
I have bought a base station and 4 cameras. 3 cameras have set up fine but the fourth kept coming up as offline. I have tried taking the batteries out etc and eventually removed the device and tried adding it again but it will not add. It tries to sync with the base station and flashes blue but now wont connect (although it was connected previously but showing as offline). Any help appreciated. Thanks
Just make sure your doing a quick push on the Base ( not a hold ) and then a couple secs later the sync button on the camera.
Open and close the battery door to reset the camera, use REMOVE DEVICE again and then bring it back as new...
If still NG, contact Netgear
