My wife recently moved her 97 yr old mother into a nursing home. She would like to install a camera in her room to remote monitor via her iphone when ever she wants. Nursing home does have wifi available to patients. Is there an Arlo camera suitable for this application?
You likely will need consent from the nursing home. They might not allow it at all, or they might insist that the microphones be disabled.
Even if they are ok with it, it is possible that their wifi authentication might not be compatible with Arlo. Many business wifi setups redirect you to their own landing page when you first connect, and either make you log in or accept their terms of service. That setup won't work with IP cameras.
That said, if they allow it and their wifi doesn't require logging in/accepting terms, then I'd suggest an Arlo Q for this. It's an indoor camera that doesn't need a base.
Another option would be the Arlo Go. That uses mobile data, so it wouldn't use the nursing home wifi. But of course you'd need to pay the mobile carrier (and pick a carrier that gets good service inside the building).
Arlo bases all need wired ethernet connections (not wifi) - which probably rules out the original Arlo WireFree, all Pro models, and the Ultra for this.
