Npot able to detect Arlo base station
  • 1 Reply
  • 2508 Views
sandeep23
All,
I am not able to detect the Arlo base station from my laptop connected to the same router after a power outage. Before the outage everything was working great.
The base station shows the Power, Globe and the Camera LED as green.
I tried doing the factory reset by pressing the reset button and the sync button at the same time, but nothing happens. The LEDS never turn to Amber.
What should I do?
The above is not accurate...
The RE-SET is Hold in the RESET BUTTON only for about 10 secs...till the front Leds flash.
Then let the base come back online... you may have to re-sync the cameras after
