Notifications
My notification on movement has now been going off twice instead of the prior just once. Anyone know if that can be changed to go back to just once?
5 REPLIES 5
Is it the exact same notification or is it the notification and then the clip of what the camera had went off for?
It is the exact same click one after the other with a second or 2 in between. The text information also comes up twice.
Do you mind sending me a screenshot?
I’ll try. Motion detected on the garage camera then it clicks and repeats it again.
Are you on iOS or Android and please provide the software you are on?
