Recently we get notice of motion and it states that it is from which camera but when you look in library it shows pictures from camera with a different name.
It sounds like you have to re - create you modes, OR you can go in and check the ones you have. ( use edit )
If you remove a camera ( remove device ) in settings and bring it back as new ( as resync ), it will automatically rebuild the default mode for each camera
THANK YOU for the solution!!
I removed the device and then resynced it.
FYI - This problem occured after I replaced the batteries with "Arlo Approved" TENERGY rechargable batteries. Not sure if that caused the problem?
