No drill mount option for cameras?
I want to put my cameras outside but I do not want to drill holes in my brand new vinyl siding. Is there another way to mount these things without drilling? I want to put them right next to my outdoor lights, if Netgear could develop some kind of screw on clamp then I could mount them right to the light support. I'm currently trying to work out a way to do it with either pipe clamps or zip ties. Has anyone else tried this?
Or some have used double side tape ( automotive molding type ) and the heavy type of command strips.... test some of them out.
