No available ports on my Netgear router
  • 2 Replies
  • 17358 Views
thusband
Can I use a Netgear powered Ethernet switch (5 port) to add a port?
Don't see why not since the bases have MAC addresses for packet switching
Netgear will have to confirm as it's above my pay grade 🙂
ChristineT
Good afternoon thusband,
Yes, you should be able to install your base station and connect to an open port on your NETGEAR switch. For good measure, I just tested this and it connected to the data center as expected.
One thing to note: the base station does not support POE (power over Ethernet) at this time so you would still need to plug the base station into a power outlet.
Hope this helps!
Best Regards,
Christine
Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
