No Ethernet port available
All of my Ethernet ports are taken. Is there another way to connect the base station to the router.
No...
But you can add a simple SWITCH to add additional ports. Amazon sells them from $10 to $50.... your choice on needs
PS this is the Q section and it would be more appropriate in the Wire-Free install section
