Why has my Arlo 4 camera system stopped recording and sending emails?
Are the running men in the Devices tab for each camera gray or black? If gray, recording is disabled. Check your enabled mode to ensure it's still enabled or the schedule is set correctly. Restarting the base may help.
Restarting base fixed the problem.
James134,
Can you live stream your cameras and manually record? Does that produce content in the library?
Do you see the same behavior from other browser/devices? Be sure you do not have a library filter set (if you do this may be hiding the recordings you are expecting to see).
Are you still seeing this behavior?
SuJamMillhouse,
Check your modes/rules and make sure they are set up correctly to produce a recording.
To further isolate the issue, you might consider, recreating a custom mode from scratch and test that mode to see if you still get the same results.
Please let me know if you are still seeing this behavior,
