Night Vision
  • 2 Replies
  • 3180 Views
Sclancaster
Hoe do you adjust the night vision as mine is way to dark?
There is no adjustment on the IR illumination. It auto-turns on ( and cam goes b/w ) if light level is low enough.
The range is good to about max 20+/-  feet ( more in the center, less on the outer edges )
see pic, the 3 ft stump in center is 25 ft, camera is 6 ft high
Search for "IR spotlights" to enhance the distance.  Just make sure they're 850nm ones, not 950nm.  Normal outdoor lighting, perhaps also motion-controlled, helps, too.
