Newbie question which system to get
  • 1 Reply
  • 3273 Views
Falcon123
Hello. Would someone be able to kindly direct my into which system may be best for my needs. Thanks.
Desired needs:
The purpose mainly would be to monitor my own house to make sure my older teenagers friends don't come over for  a "teenage gathering" when we are away or at work.
  1. At leat one camera outside. 3 inside camera. I will be getting a Samsung Smart Things Hub
  2. I can connect them to power if need be. But how good is the wireless? About how long will the batter last.
  3. I would like to view a live stream on demand when I am away on my Android phone. Wife has iPhone.
  4. I would like ease of use and do not want to become a techie to set up and maintain.
  5. Does video get recorded locally or in the cloud?
Thanks for any help you can offer.
1) ok, Outside I would recommend the Pro camera ( battery or AC, AC FOR OUTDOORS NOT RELEASED YET), Inside the Q camera( ac , indoor only )
2) Pro can be ac or battery pack, Q is AC only/indoors.. wireless range is base on the walls/ material the signal goes thru... Battery on Pro is good imo for 3 months+ spec useage
3) there are apps fo android and ios, also PC via browser
4) not overly hard but a bit of learnig curve to learn Modes ( custom create of same ) ... read FAQs for most answers
5) All video on both go to cloud, the Pro has a usd drive backup but not directly accesable ( drive must be ejected and played in another device for mp4 files )
