New wireless router
  • 4 Replies
  • 5105 Views
Jasonr002
All cameras had strong WiFi signals to the base station prior to the install of my new wireless router. I installed the Linksys EA9500 max stream AC5400. Now 3 of my 7 Pro 2 Cameras have poor WiFi connection. The base station is approx 15ft from the router.
Jasonr002,
You might try elevating the base station to see if that will help with the signal strength.
If you can, reboot the arlo base unit ( power button , off-on ) and let it come back online...it should come up on the same channel as the router ( if close enough ) and maybe the signals will be better as it sounds like interference.
I have two bases aprox 8ft from my main router and no signal issues
Jasonr002
The cameras continue to have a poor WiFi connection. I rebooted the base station as recommended.
Jasonr002,
Jasonr002
Thank you James. Raising the base station along with a soft re-set worked.
