So I'm new to this, I've read some of the threads and still can't get my camera to sync. I have pressed the sync button on the base station and released. The only light that's flashing green is the camera sync light. "Not the USB light" my batteries in the camera are in there correct, when I close the cam for the light flashes but when I try to sync nothing happens. Help please.
So, just to make sure you're set up right:
1. Your base station is showing the two left LEDs green.
2. You're pressing the sync button on the base station briefly (under 1/2 second).
3. You press the button on the camera briefly.
4. The third LED from the left on the base station blinks green.
What is happening with the LED on the camera?
