New batteries died in 24 hrs
There can be various reasons for quick battery drain - WiFi interference from other wireless devices, poor signal levels due to camera/base postioning, base station turned off, etc. Tell us about signal level, relative position of the camera relative to the base (walls, etc. that may block signal). Also, the total number of minutes of recording and live viewing all add up and can drain batteries quickly. You can add up the number of minutes recording in the Library and estimate the time spent live viewing. ~4-5 minutes TOTAL per day is what will give you spec battery life.
If it turns out that the camera really is defective, you have two choices. If the system is new enough, you can swap for another system at the store. Otherwise you need to create a trouble ticket using the Support link at the top here and then Contact Support on the right.
