New app - cannot mute push notifications more than 24hrs
Downloaded new Arlo app but unable to mute push notifications for more than 24hrs?!
Hi Slimbob,
Currently you can only mute push notifications for up to 24 hours. Feel free to post your suggestion on the Idea Exchange Board if you like 🙂
Thanks Jess. I really think this change from the old app is not good!!
It is annoying I cannot turn off push notifications permanently.
Why was this changed?
HATE the new Arlo app.
Why did you remove the ability to permanently mute push notifications?
I am fed up with receiving these.
If you want to turn off push notifications permanently than temporarily, then you can do this by editing your rules. Feel free to read here on how to disable on your iOS/Android device:
