New Setup/ No Cameras Connected
  • 4 Replies
  • 2743 Views
thekyniche
I am setting up a new Arlo. I have set up the system and synced all cameras twice and I still have no cameras connected.
4 Camera should not all be failing to sync. This beiing web-based, are there any network issues? Very frustrating after investing this much in your system
Any help would be appreciated
airone07
these days there are a lot of problems with the server software arlo because there is a software update I also had synchronization problems two days ago,  but this morning I tried again after speaking with the technical assistance.
Then tonight I realized that the software has been updated,probably if you try to do now should go.
I write from Italy
thekyniche
Unfortunately, I just tried again and the cameras are not connected... I goes I'll wait.
Wonder if Netgear will prorate their profits to my account??
airone07
try to contact the technical service support, they are able to remotely see if there are any problems with your system
snip3rboy
Hi @thekyniche
There were major system updates today that could have impacted your setup. You can try the following:
1. Re-sync your cameras to the base station again
2. Or, Remove the base station from your account and add it again
To Remove the Base Station from your account:
  Log-in
  Go to Settings > Devices > Your Base Station. Make sure your base station is Online
  Click 'Remove Device' - This will remove the base station from your account
    Depending on what version of the firmware your base station is on, you may need to Factory Reset the device after this step. See item #8 on this page https://community.netgear.com/t5/Arlo-Knowledge-Base/My-Arlo-base-station-is-offline-how-can-I-troub... on how to do this.
To Add the Base Station back to your account:
  Go to Cameras > Add Device
  Select Base Station and follow the instructions
  Then sync the cameras again
