New Arlo install - no motion or record?
Try logging in with the web interface to see if there may be a problem withe app you are using.
Type this into a browser
Thank you for advice , tried that numerous times along with re-sync cameras ,there is no mode banner for the basic plan ? I can not create any functions for cameras . Manage camera status tells me to move cameras hear ,inactive cameras move above to activate , Can not complete this task ?
The quickest thing to do is to reset the system and start fresh. Remove all devices from Settings, My Devices. Hold the reset button on the base until the LEDs flash amber. Use the Add Device button on the Devices tab to add the base and sync the cameras. That should set things right.
I'm a bit confused by your description. What LEDs are lit and what color? If the Camera LED is solid amber that indicates the base needs to be claimed. Retry the reset process, including the removal of everythinf from Settings, My Devices.
