Netgear camera Arlo camera VMC 3030 , uses 4 short batteries and no charging port
Hello,
About a year ago, I bought two Arlo VMC3030 CAMERAS. They use four short fat batteries, and there is no place to charge them on the camera.
Two questions, would it be compatible with a Pro 2 base unit and other Pro 2 cameras, and are there chargers for those batteries?
Thank you,
Suprmark1
The normal batteries are nonrechargeables. However, you can purchase a Tenergy set of rechargeables that work fine and are certified by Arlo.
The Pro series use proprietary Li-ion batteries. A charger is included in the set.
