NetGear WiFi Range Extender WN3000RP
Hi. Could anyone please tell me whether the Arlo VMS3430-100EUS 4 camera home security kit can be used in conjunction with a Netgear WiFi extender. The extender connects with my Broadband easily enough but there appears to be no WPS button on the Netgear Arlo router to recognise an extender. My house due to its construction has indifferent WiFi coverage and I was looking at ways to improve this and thus increase the places that cameras could be sited. Any help would be appreciated (the less technical the better for me!!). Thanks
I happen to have one Arlo base station connected through an old Netgear WiFi extender. You don't need WPS or anything other than an Ethernet cable between the base and extender to work as long as the extender has connection to your router.
Or am I misunderstanding?
Since the AArlo wireless cameras do not use your home WiFi but only the dedicated WiFi between the base and cameras, an extender won't do anything for you. The solution to a situation where signal is bad in one part of the house but good in another is to use a second base station. In this case, your WiFi extender would be useful to be able to position that second base optimally for the other part of the house.
Thanks that's what I had concluded but thought it was worth putting the question out there in case someone had managed to think of another way around it without the purchase of a second base unit.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
