Need a wireless (no base station), battery powered, continuous recording camera for business
  • 2 Replies
  • 1138 Views
danoldenkamp
The boss wants to drop a camera (magnetic mount) in any of our warehouses (Wifi available) , view the camera temporarily remotely, and then pick up the camera at end of day and review the video.
Arlo Pro 2 is out because it doesn't do local SD Card storage
Arlo Q doesn't have a battery
Arlo Go is 4G only and we need continuous recording.  (Well 300 second motion recording is ok, as there should be constant motion)
Arlo Ultra looks like it has to be within range of a base station.
Does arlo have any products that could work for us?
All battery powered cameras have a finite run time...
Don't think any of the Arlo cams will fit your needs.
Sound like you need more of a covert recording camera that records directly to a mem card.
try https://www.supercircuits.com/
or
https://www.brickhousesecurity.com/hidden-cameras/camscura-wifi/
You could consider a large capacity USB battery for a Q camera to make it battery-operated.
