My bateries drain 10% in 12 hours, I adjusted all to minimum and nothing, the proiduct is defective. What to do? is expensive and has a goos performance.
Thanks.
Open and close the battery door to reset the camera
If still problems with excessive drain of battery, contact Netgear Support.
Mami,
This could also be related to poor signal strength or interference. Are the cameras dropping offline? What does the signal strength show for the cameras?
