My Netgear vmb3000 will not connect to the eithernet. I just had new fiber installed with 100 meg,
  • 1448 Views
Scruggs
cannot get an eithernet connection.
Tried a different cable and router port? If you gently pull on the cable on both ends does the cable come out without needing to push down on the connector tab? It may also be an issue with the new router not supporting a 100Mbps connection. You can try going into the router settings to see if you can change an appropriate setting. Check the manual, too.
Scruggs
Cables good even tried several cat5. Starting to think the router does not support the new 100meg.
You might want to check the specs/manual for the router to verify that. Also look at the LEDs on the port - if none are lit, that would imply no connection.
