My Library displays video from only one camera
  • 2 Replies
  • 3827 Views
write2nashok
My camera LED flash when motion is detected but I am not receiving video in my library.
If the led is flashing , it sounds like your camera is on test motion mode.... it does not record in test mode
You must arm the camera by the MODE, Use the default ARMED, check on the live view screen and verify the 'running man' on all cameras is BLACK , not gray ( black is ON )
Adding to TomMac's response above, check your library filter settings. You could also have a filter set in the library filtering out content from your other devices.
