My Arlo Wire-Free add device to Mobile Router
  • 4841 Views
Philby12
Hi all,
Has anyone tried to add a Arlo Wirefree Camera to a Nighthawk M1 Mobile router?
Instructions say to Enable Arlo on the Mobile Router from within the Neatgear Mobile app.
I have the App on Iphone 7, logged into Router, but cannot see where one actually does this?
As per snapshot
Would like to do this as having trouble getting base station to stay on wired Bigpond cable network.
PhilArloArlo
StevenL
The cameras used to be able to connect directly to certain Netgear routers, however Netgear removed that capability a while ago.  You must connect the Arlo base station with the ethernet cable to your router, then sync the cameras to the base station.
manfredz
Hero
Hero
Can you accomplish the same thing by using a wifi extender with an ethernet port?
StevenL
Yes.  Plug the base station via ethernet into the extender, then sync the cameras to the base station as usual.
