My Arlo Wire-Free Camera
  • 1 Reply
  • 2521 Views
JoeM47
I have a 4 camera Arlo security system and can only sync 3 of the 4 cameras.  New batteries and I have tried many times and just keep getting the amber light.
First, open and close the battery door to reset the camera (make sure the batteries are installed correctly) then make sure you're only briefly pressing the sync button on the base - don't hold it.  If that doesn't work, you can either return the system to the store and swap for another or contact support - https://www.arlo.com/en-us/support/contact.aspx
