  • 1 Reply
  • 3345 Views
Vintage
I just purchased the Arlo two pack camera set and am very impressed with it.
I am going to set it up at my moms place so I can check on her remotely.
I woud also like to purchase an Arlo 4 pack (with base station) and install it at my home.
Each location will have a separate account name.
Is it possible with the IOS Arlo app to easily switch betwen account names? It would be idea that once I login with the touch id if Arlo either presented all 6 cameras or asked what account I wanted to use.
Or could I basically grant access to one account to see the other account.
Sorry if this has been asked before. I did do a little searching before I asked.
Yes, use Settings, Grant Access from one account to the other email address. Select the cameras and add privileges as appropriate. Follow the emailed directions and you'll see all cameras in one login.
