I'd love an option when in the library view to tap on a select button that would allow you to multi-select any videos that you would like to bulk delete.
Thanks,
Rick
rickengle,
This can be done but is a little different depending on which client you are using:
Web client: Within library, click "Select" and then click each desired video, click delete.
Android: Within library, tap and hold the desired video, after it has been selected, select any additional videos, click delete.
iOS: Within library, tap "Select" and then tap each desired video, click delete.
rickengle,
