Mounting next to an external light
  • 2 Replies
  • 17690 Views
am97122
Anyone have any issues mounting the camera next to an external light. Is there any recommendation for being close to a light source.
Mounting outside is not a problem re external lighting.... but make sure if possible the the camera is mounted so the light isn't going in the lens.
In other words, mount the camera out past the lighting if possible ( or on the side by a few feet )
Best is to temp mount the camera and check how it works prior to a permanent mount.
am97122
Thank you TomMac. Absolutely helps..
