Mounting Camers
  • 2070 Views
Zeke2
I'm trying to mount a camera (ARLO Wireless) on a side wall to down a 10' wide driveway. The magnetic mount will not let the camera face in a direction that allows the wanted coverage. The camera aims at least 30 degrees off the line of sight I need.  Basically I need to look parallel to the side of my house.  Any ideas?  Is there a "standoff" available, or wedges (not shingle leveling wedges) available.  If worse comes to worse, I'll have to make wedges - cut, shape, paint (make do).
steve_t
Master Master
Can you use a VMA1000 screw mount or a VMA1100 magnetic mount?
ShayneS
Here is the link to this mount if you are interested  --  .Arlo Accessories
Zeke2
Thanks for that link.  Have to go back there and rummage around a bit.  I'm trying to mount to a verticle Fascia board.  I'm sure I'll find a good answer and appreciate any ideas/suggestions.  The ceiling mount looks like it would give good clearance for pointing the camera as I would like.  Maybe if it can be fastened to a ceiling it could also be fastened to a vert side wall.
