Alert received video starts with bright yellow screen nothing in video that caused motion detection all three cameras do it from time to time
Not quite sure what you're referring to but the brief brightness flash at the beginning is likely due to the autoexposure figuring out the exposure needed. Very typical and nothing to worry about.
Can you post a snapshot ...also info on the Hardware verion and sw running ( under settings/ info )
All i can say at this point without more info is take ONE of the cameras and reset it ( all to defaults ), check signal level. and download the video and see if it is the same on a local machine
https://arlo.netgear.com/hmsweb/users/library/share/link/45CC2DDA1519AAD1_201706
this vid shows exactly what happens
i cant figure out how to get screen shots in here
I believe you are right about camera setting auto exposure
thx
