Motion detection range
  • 1 Reply
  • 3250 Views
fernandezls
When I first installed my Arlo Wire-Free Camera it was detecting motion almost 10 yards away.  After three days it's only detecting about 5 yards.  Is there a setting where I can adjust the range?  Thanks.
There's the sensitivity setting ng inside each rule in each mode that can be set. However, there can also be a difference in the IR level from the current subjects that's different from what it used to be, maybe caused by Sun's angle, size of the subject, clothing ,etc. It may just be normal.
