Modes off is gone
Hi, I just got my Arlo set up and when messing around with the modes I deleted the all motion Off modes. I've tried to set up a new modes which will not record or detect motion but it doesn't let me save it. Any one can help? should I just reset the all thing? Thanks in advance
If you do a full re-set ( hold in the Base reset button for about 10 seconds till front LEDs flash amber ) it will restore the two defaults ARMED and DISARMED.
Setup again as new.
When you change/edit modes, it's safer to create new copies of modes and modify them ( over originals )
