Modes and Schedules
Hi, Please help...I have 3 cameras, and 2 have been set up with a Schedule and work fine. However the 3rd camera, a Arlo wireless, isn't displayed as a "Device" when I'm in the "Modes" page. The other 2 cameras are shown, and the Base is shown. So, I'm unable to set a schedule for the wireless Arlo camera.
Also, should the Base be on a schedule, or just Armed 24-7 to accomodate the different schedules for the cameras.
Thanks for your input!!!
if i understand you correctly you are trying to set a schedule for a cam?
you set your cams in modes and set those modes into your schedule
I've successfully used Modes and Scheduling for 2 cams (both wired). I can't seem to do the same with the wireless Arlo because it doesn't show as a device when I'm in the Modes screen. The Modes screen only shows my other two wired cams, and the base station.
Click on the BASE station icon , the camera should appear
