- 2
Hi
Having this problem just now, first it was no more recording during motion detect since the 24/3 and Judy now everything is offline even though there 3 green lights. Have reset everything and removed and add the device, cleared cache rinse and repeated 3 times. My internet is fine as I am posting this using my PC. Tried to log in using seen browser. Same result.
Earlier today, we experienced some technical issues with the Arlo environment and some customers may have been unable to connect to their cameras. We have restored full functionality and you should no longer be experiencing issues. We apologize for any inconvenience this may have caused.
Thank you for being part of the Arlo Family!
my view and connection to the servers have been restored.
but the cameras do no record to the cloud, this is both in browser and through the arlo android app and the iOS version.
Have you power cycled your base?
Tell us exactly what your symptoms are as well as what you've tried to resolve the issue.
I've resynced my cams, reset base and my router, removed and re added the camera. Have power cycled the devices multiple times. The firmwares on the base and cameras are the latest.
Only the videos that I triggered the recording are showing in the app. The motion detected ones are not.
2 hours after my post (3am australian time) everything seemed to be resolved. thanks to the support person that has fixed it for me.
I bought refurb system brom Best Buy and tried and tried to setup but didn't get far. Netgear support did extensive troubleshooting until they determined to base station was defective and shipped me a new one. Smooth sailing with a great system since
Cacmac wrote:
I received an Arlo system for Christmas because it would be EASY! Here we are in April and still a no go. Had wifi but had to get a modem. Supposed to be wireless. Got the magnets anchored around the property. Got app on all devices. Internet working to run them. Set up base, no problems, all three lights green. Three of four cameras synced. Took out battery and got it to sync. Went to phone and warning of update. Did update and now all say offline. Unplugged. Turned off. Unplugged wireless. Reset. Nothing, yellow light. Deleted device(base station). Now thinks there is no internet. Please advise before it all goes back to Best Buy! Spent four hours on a 20 minute job.
Which LED is yellow - Internet? That means the base has an IP address from the router but no connection to the servers. That can be a config issue with the router or possibly a bad base. Open a case with support.
- 2
