Hello. I've recently lost my phone which has my Arlo app installed and logged in. Im worried the founder may guess the phones lock screen gaining access to all my apps, specificity my Arlo app.
I am wondering if there is a way for me to log out of all the devices remotely making it a requirement for me to manually log back in. My whole system is currently off at the moment until i can figure this situation out.
Thank You
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-change-my-Arlo-password/ta-p/4377
change PW and also your email ( in case they can view on you phone..
wouldn't the easiest thing be to get your cell provider to kill your lost cell?
Login on a computor and it will auto log out on you mobile phone.
