Lose sync with base and camera
Lose sync with base and camera. New battery install re sync after a day camera loses sync with base and have to redo the process again. Its frustrating cameras are mounted high and always taking out the ladder. Any suggestions?
Are all cameras loosing sync or just one?
If one , swap it with the other to see if it's camera or location.
All 5 cameras
It's possible that you have something near the base that's interfering with the WiFi signal between the base and the camera. Check out any 2.4GHz devices (cordless phones, microwave ovens, etc.) that could be an issue. Moving the base using a longer cable may help or use a WiFi extender with an Ethernet port.
I'll try that and let you know the results. Thanks
