Login unknown error
  • 1177 Views
bibibo
Hello,
I am blocked out logging in on Arlo portal or any app iOS or Android.
Issue appeared when configuring Arlo on Home Assistant and setting up 2FA method (IMAP). Initially worked well for a few hours but then I was not authenticated anymore.
Can you please advise?
Thank you
bibibo
After 24h I was able to login again. Resetting the password did not help. No clue what was the issue.
BrookeN
Have you tried to reset the password and see if you are able to login that way?
bibibo
BrookeN
Thank you for the update. If you have any other questions, please reach back out. Have a great rest of your week.
