Cannot login via My Arlo. Put in credentials and get the circle and then nothing. No error messages. Can login to this community fine using the same credentials. Using Chrome. Cleared cookies, cache and restarted. Did not resolve. Any more tricks?
Added trusted URLs:
I'm in. Problem solved
What OS version? Is everything updated? Have you tried a different browser? Some Internet security software cn be an issue, specifically Kaspersky.
@ChrisChensy wrote:
I don’t think this is related to firewall as I use Mac without any third-party antivirus software.
This is about the silliest thing I've ever heard (retired IT here). ANYONE without antivirus is at risk, potentially putting many others at risk. The Mac is NOT safe from intrusions - period.
As for the current issue, what is the error? What have you tried? What browser are you using? Have you tried others?
What OS version?
Search for Kaspersky here - there are a number of threads with solutions, including recent ones. I don't use them so can't give exact directions but it's a matter of whitelisting arlo.com.
Tried IE 11. Did not solve problem. Will research Kaspersky solutions.
Access to XMLHttpRequest at 'https://ocapi-app.arlo.com/api/auth' from origin 'https://my.arlo.com' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I switched to PC and had the same error. It only works when I switch to Mobile network (hotspot). It seems Google Wi-fi does not have any settings related to firewall. My Mac does not have firewall either.
