Locked out of Arlo app from one device. Says to update app and takes me to App Store but no update?
  • 2 Replies
  • 1258 Views
Daydream
So I was messing with the settings and accidentally locked out my tablet from being able to use the app. Whenever I open it it says Arlo needs and update and takes me to the App Store however, it doesn’t need the update. Is there any way to reverse this???
dcfox1
Try deleting the app and do a fresh install of it.
Also, depending on the version of the tablet's OS, you may not be able to update the app. The backwards compatibility only goes so far. You can check the requirements in the app store and/or in the support section here.
