Replaced batteries, synced camera, now doesn't record on movement. Schedule is the same, all motion all the time. Will show a tree of Red lights when motion is detected.
This sounds like an extender issue, not Arlo. You could try removing the Arlo Ethernet cable to see what happens. Restart the extender and check for proper operation and then re-add Arlo.
