Is the Arlo camera LED visible at night? Will it reveal itself to a thief?
  • 1 Reply
  • 3241 Views
jafo252
Hi, thinking about getting this but I am concerned that the LED lights might reveal itself at night...allowing a thief to remove or disable the camera....what do other owners think....If you are looking for a camera at night, can you tell its there?
It's a dim but visible light - 850nm. If you're looking at it, you'll notice it but, if not, you'll likely not.
