Installed arlo 3 now my old arlo system wont work
I set up an arlo 3 system then my old arlo stopped working. The base station simply wont pick up the cameras - either that or the app wont show them.
Are the old cameras on a different base?
Did you add the new cameras to your existing account, or set up a new account?
@amanda66 wrote:
They are different bases, same account
And the original base station is not showing up in the account???
@amanda66 wrote:
I deleted 3 cameras and tried to re-sync them but either the app doesn’t show them or the base station isn’t picking them up.
Not sure why you did that - were you trying to move them to the new base?
You have to re-add the cameras (since you deleted them). Have you tried using the web ui instead of the app?
@amanda66 wrote:
The remaining camera shows as offline in the app.
Is the old base online?
I deleted them so I could re-add and sync them...also why I left one as it was.
@amanda66 wrote:
Same problem from a pc as from the app. Old base and remaining camera show but camera shows offline.
Is the old base also off-line? Have you tried restarting it?
@amanda66 wrote:
Old base is online. I have shut it down and restarted and it comes back online fine. Hit the sync buttons and the cameras flash orange once in a while while the base station tries looking for them. Cameras never connect.
Odd. This is all on the original account?
Have you tried adding one of the deleted cameras to the new base?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
@amanda66 wrote:
Moved the old base station from LAN 4 port in the modem (where it’s always been) to LAN1 (new base station is on LAN 2) Lo and behold it works... Don’t know why???
Could be a failed LAN port on the router. You could try moving the second base to LAN 4, and see what happens.
Or leave well enough alone...
