Identifying my cameras
How far back do you need to go? The original wireless cameras take 4 CR123 batteries and have a silver ring around the face. The Pro has a rechargeable square battery and has a black ring while the Pro 2 is virtually the same but has a white ring. The newer cameras including the Ultras, Pro 3 and Pro 4 are visually the same so looking in the battery compartment for a VMC number (the "C" is for a camera) would be needed to tell the difference. You could then just Google for that model and see what pops up if you don't know.
I agree that the model should be in the camera info. I name the cameras as I install them with the model ("Ultra neighbors" for instance) to make it easier.
Original Arlo ( HD ) uses 4 - 123 cells
Pro has Black Bezel
Pro2 has White Bezel
After that it gets a bit harder...
I put a notation on the camera with a sharpie pen with the number of model
As a side note, I put in the name ( on app/web ) the last date I changed the battery ;
exp: rear yard (3-15)
