I need to change the time on my arlo
  • 17592 Views
  • 3 Likes
sueg128
I can not figure out how to change the time on my recordings- not referring to the length of the recording, My clock is off by 2 hours and under the instructions I googled- they refer to a pencil under that shoudl be there once I click on Armed and there is no pencil. Appreciate any help
To set the time you need to use Settings, My Devices, your base, Time Zone. Depending on your country you may need to choose carefully.
manfredz
Hero
Hero
Could it be that your time zone is wrong?  Look under settings/base
sueg128
Thank you!!! it worked!!
