I'm not able to reduce the movement sensibility
I'm not able to reduce the movement sensibility . I put 10 % and the camera notify me all the movements like 100% , is very annoying
remove the camera with remove device, pull battery then replace, bring back as new and it should now have all settings to default
thanks I will do the steps you recommend
