I'm losed Base Station from Setting.
hi there,
I'm losed Base Station from Setting. Can get nobody helping 😞
What steps have you done to set things up? We need everything in order to understand the problem. It's obvious English is a send language for you so you might try using something like Google Translate (http://translate.google.com/) to use your native language for us to help.
The more you tell us, the better we can help.
