They record in real time. But after i review the recordings, and close it out it shows 1day ago or two days ago, and they do not show how many recordings. Firmware 1.4.293 hardware H11
After further thought, i tried turning off my phone and turning it on again and it worked. Thanks to the community for your help.
The title and the message seem to be different. Are they?
For the title issue, you can't change the timestamp nor should you. Maybe more details would help.
For the message itself, I assume you're referring to the library. Is it possible you have a filter set so you're not seeing all videos from all cameras?
